Hi i have made my first pano using kuula. If you do not use the pro version of kuula you can only use 25 photos, My drone is taking 35 to make a pano, so what i did was i deleted the photos of the sky, reducing how many photos i had to make it below the 25. If i get use to making the pano i might subsribe to the pro version
What Drone?
If it’s a DJI just use the stitched photo the DJI fly app creates
Not sure what you are doing here, the amount of stitched images shouldn’t matter
Hi when i log into kuula, then i press Upload, then create tour, i get the message about how many i can upload
Should i not be pressing “create tour” i thought that is how i upload the pano pics and then it stitches them together
That is just a batch upload, Kuula does not stitch any images
Use the singe image upload and upload a stitched 360, either directly from the drone as I asked before or use a program to stitch the image for you
More info here
This is one of mine, its a direct upload from a stitched image done by the fly app directly off the SD card
