When did you go last though
Tbh we setup in one of the little out houses when I went between showers, but 70 percent⦠I am tempted⦠Plenty of cover I guess and inside flyingā¦nearly 2 years since I went thoughā¦
Then again only just got the nice 5 incher back in air!
Hopefully going to make an appearance at this one as if it is not too bad myself and @FoleyMrs will be there.
Off topic
Is (time flying > time repairing) == true
(Sorry all morning dealing with SQL)
Youāre not the only one⦠ergh⦠MS SQL Management studio can go f. itself
Oh YES
which RDMS uses double equals signs?
Hi I missed the time before the one that was cancelled wasnāt sure weāre the place was ? So today I thought take a drive and look, Matlock was a nightmare to get though but I found the place is there a magic trick to get in came across two gates the first one you can walk round but the second one no chance. Iām not going to climb over a stone wall last time I did that got two broken ankles So if thereās an easy way to get in and the weather is kind to us I will definitely be there oldtimer
This is why I hate SQL I always get the syntax wrong. Single equals.
The abomination called JIRA. And JQL.
Matlock is, indeed, a bit of a mare for the foreseeable due to major works on the A6 and its diversion through the town centreā¦
Depends which end you approached from, and if anythingās changed since I was last there (a good few months ago now).
If you park up at (1), there was just the one gate you could walk around, roughly where the red line is.
If you park at (2), it is/was possible to go in the bottom way, although it is a much longer walk and there was an area of that temporary wire fencing below the new flats, as indicated by the oval, but there were gaps you could squeeze through.
At one point, theyād also tried to isolate the old Permanite factory itself with this temporary fencing, but that was mostly laid flat last time I was there.
As Iām possibly the most local, Iāll have a little trip out this evening and see what the current situation is.
For information, the A6 is closed at (3), so youāll be sent round the indicated diversion if approaching from/leaving by the South East.
Thank you it looks as if I was at No 1 thatās the first gate about 100m further on is another gate which I couldnāt see a way round that had a sign reading anti climbing paint and cctv 24h monitoring I think thatās a joke,if you do go today can you let us know if Iām right about the gates oldtimer 71
Ok well it might be a no go all round then, see what Jez comes back with later and fingers crossed with the weather
Itās not good, chaps.
Shame really as now @Foley has some good metal detecting skillsā¦
Then again my Long lost quad nowhere near the bando⦠A good half mile radius lol
Iāll never avenge Matlockā¦
Cheers for the reccy though @Earwig
Iām sorry but I agree not worth the aggravation oldtimer 71 Another depressing weekend
Ill give it a month and the gates will be back open
Hopefully you and/or @Earwig can keep an eye out. Iāll also keep watching the FB groups for it. I did see that people couldnāt get in last weekend⦠Will let you all know. Thereās always chesterfield
Iām on a WhatsApp group and 1 of the guys said he had the key for the lock
