Mavic 2 Pro. Gimbal alignment in flight
Flying the Mavic at a distance and panning the gimbal left and right… then realised that I didn’t know if the the gimbal had realigned with the body of the drone… Is there a way of doing this or a visual cue on the FPV?
In the Go4 app, click on the 3 dots at top right and enter the settings.
Select the Gimbal icon, and within there there’s a “Gimbal Recalibration”.
Make sure the drone is on a perfectly level surface, and that the camera has plenty of objects in view (not a plain painted wall, for instance).
That takes a couple of minutes and all should be correct.
… and welcome to GADC, too. :+1:
Hi thanks for that. I was actually looking for a way to be sure the gimbal has recentred in the horizontal during flight. similar to the vertical where there’s and indicator.
