It’s what they do with most issues ![]()
Thanks for that snippet of information, as this was my first dealing direct with DJI repair I wasn’t aware of this.
DJI repackage and heat shrink all their refurbs too. Much like Apple do.
Moved your post to an existing thread on this error code.
Out of interest why don’t you let iOS update automatically? And how do you do it manually - via PC?
iOS does not remove the old version, it just writes the new version over the top.
If I want to update to a newer version I’ll uninstall the old version and do a soft reset to get rid of all the left behinds , then just add the new version through the App Store
I had a little prang with my Mini last night. Now I’m getting the gimbal is stuck error message. The gimbal seems to move freely when starting up but gets stuck at 10% if I try to calibrate it. I’ve tried blowing air into it to try and free any dirt that might be in it but I’ve had no joy with that. Anyone had this issue before?
Moved your post to this thread since Code 40002 is also mentioned above.
Its OK, I’ve managed to fix it. A tiny cable had come loose actually in the gimbal. Clipped it back on a it’s all good now.
