Does the mavic air charger only charge 1 battery at a time? Seems odd that I have 3 batteries on charge but only one has lights on indicating that it is charging.
If it’s like the MP charger, it starts with the one that needs least charge and works through them in sequence.
Yes mate, what @OzoneVibe said. There are chargers available that will charge all at the same time but they look about the size of a brick
Thanks. I find the manuals are not helpful as always with modern technical gear. You seem to have work things out for yourself- or ask friends
