Mini 4 Pro connecting to satellites
Does anyone else find that the Mini 4 Pro takes a long time to connect to enough satellites?
Only recently bought it, but having owned a Mini 3 Pro and Air 3, there’s a huge difference in this respect
Use DJI assistant to refresh the firmware and test again, the first time it will take a good few minutes but on a battery change it is a hot start so you should acquire them quickly
If the drone has not been used for some time or you move to a location far from the previous it can take time
Got nothing to compare with DJI wise but mine appears to take almost as long as a couple of other gps walking/tracking gadgets I have. Certainly a few minutes and I spend the time checking settings on the RC2. Worse if part of the sky is obscured by buildings or trees but it’s nice to see the number climbing so I know it’s doing something. Usually wait till the mid teens before I take off……
