Navigation Warning
This Navigation warning has come up over Leighton Buzzard is it just a warning ? can i still fly in this area ?
i just need someone to say if this is right I don’t want to make a mistake I don’t want to go to prison :toolbox: :old_key:
thanks for any help in advance
It’s only “indicating a possible hazard”.
Full NOTAM Text
Q) EGTT/QWGLW/IV/M/AW/000/054/5156N00038W007 A) EGGW B) FROM: 21/08/21 09:00 C) TO: 21/08/29 18:00 E) MAJOR GLIDING COMPETITION. INTENSE ACT WI 6NM RADIUS 515602N 0003807W (LEIGHTON BUZZARD, BEDFORDSHIRE). UP TO 40 GLIDERS AND 5 TUG ACFT MAY PARTICIPATE. ACCESS TO CONTROLLED AIRSPACE SUBJ ATC CLR. FOR DAILY ROUTE INFO: WWW.GLIDINGTASKS.CO.UK OR 01525 691936 AND 119.905 MHZ. 2021-08-0041/AS3. LOWER: SFC UPPER: 5400FT AMSL SCHEDULE: 0900-1800
Yes, you can fly here.
It’s not a restricted airspace, but please check their website or call the phone number (that’s what it’s there for) and use some common sense at the time of flying.
Thank you and do you know about “Class D Airspace”? what this means?
You needn’t usually worry about Class D airspace as you’re flying a drone and are flying it within the confines of the Drone Code.
Have a look here: https://dronescene.co.uk/about#ClassD
Thanks again, normally i just avoid flying in everting yellow now i have a better understanding thanks to you :+1:
