what are you using to run this, I have the DJI FPV & could really do with putting tons of hours into flying this compared to the actual expensive hardware, thanks Tony
Thought I may as well necro-bump this thread rather than starting a new one.
The new “Surtur” map for LiftOff just dropped. It is indeed, huge and epic but… it’s a lot of open space with just a few points of interest to play with. The volcano is fun, and the geothermal plant, and you can get to the top of the mountains and dive back down them. If you want cinematic cruising, then I think the Tryp environments are nicer, but if you already have LiftOff and don’t want to stump up for yet another sim, then the Surtur map does offer something new.
I would have thought a slightly higher cover charge would be better. He needs a dozen people to break even at current pricing, and that’s starting to feel like a crowd. Of course, as someone who already has an hour each way and an 80 mile round trip, keeping the cost down appeals to me.
I did have a bit of a scout around to see if I could find similar suitable venues a bit closer to home but not really had much luck.
I suspected that might be the case. That farmhouse looks very close.
Bi-annual or Quarterly might be another way. If you use something a lot and can make a saving by doing it that way, then it might hook people. But if you only do it once in a while then it might not.
I mentioned Magpie Mine to Yith, late December. Would need to be an early morning rip, because they apparently hate quadcopters and are generally hostile. But if you fly at times when no one is on site, it should be fine. I want to fly it later in the year when i can maybe rock up at 6am and just rip a few packs then move on. If others were to be there too, it would be nice as well.
