Hey Fellows,
I have been trying out NDL since a couple of weeks , but don`t have any result until now. The first attempt lead into a loop, one battery broke through downgrading the current firmware ( 1.02.0100) to the appropriate from NLD determined 1.1.0100.
I `ve been told to wait until the succsessionel NLD assistent will be out - so I did. Same problem. The current firmware is not beeing recogniced, flashing failed.
Following contact with the NLD support ( I have been asked 10 times the same, what assisnt are you running?) nearly close to a weak - minded correspondence ending up that they came to the conclusion " their database has not been updated yet)
meanwhile 20 mails
Ok, ( 14.07.2018) the NLD 1.7.03 is out - no difference
NLD support answer: " Please fill out the firmware form and send it in. Screenshots don’t work, since we need the data to import to our servers."
Thats just about the limit. The talk about an omnious " firmware form" no idea what this should be and where it can be found. Instead of helping or at least they should admid that NLD doesn
t work with Inspire 2
Anyone in here having ideas or oppinions. experience with NLD?
