Bob @bob
I read of someone having similar on Inspire 1, they had to tap map and make it full screen, then go back to video screen, just tap between the 2 a couple of times and their video appeared.
Seems very unlikely, but worth a try.
Let us know how you get on
An interesting idea ⌠but he was getting no video from the HDMI port on the RC, either ⌠so, no video at the RC to feed to either the HDMI monitor or the phone app.
Yes I read that, I even thought faulty cable, but unlikely if happening on both hdmi cable and cable on whatever device he is using.
Am sure there must be someone nearby with a Inspire 1 that can assist
Just found this, not sure if worth trying @bob
Resetting your RC if you get the dreaded âno video signalâ on your master or slave
Follow the following sequences to reset both your master and slave RC.
- Go to RC Settings, put the master remote to âOFFâ then put it back to âMASTERâ
- Press the C1 + C2 + Shutter buttons and keep them pressed and TURN OFF the controller.
- Whilst keeping the C1 + C2 + Shutter buttons depressed, TURN ON the controller.
The controller will do a reset and the video link will be back.
Repeat above 1-3 for Slave RC.
LED on RC will be RED to indicate success.
Now that sounds far more promising!
Fingers Crossed
Great!! will try tonightâŚ
i will let u know if it worksâŚ
i have tried a reset (found on DJiâs forum) it did not include step one.
hopefully this version will work!
Thank you!
