Friend of mine, @Steel-eye from Sheffield, sent me this photo of a beer that should be considered for the GADC bar - if we had one!
That brewery is a few miles from where I live, I better go and taste it to see if its suitable for the new bar
Good plan. Make sure you taste it thoroughly. You might need several pints before you decide but I’m sure you can handle that hardship.
Should make it clear that the pint behind the card is not stout of course -
just my bitter being used as a prop. Is that a pun? Cheers!
Hmmm…
I’ve often found that I need to return to said bar on (multiple) different dates too.
In order to re-check again.
Just in case
