Mavic pro with Litchi .
Ok Shane which bit was litchi?
Flying through the farmhouse can’t be done with litchi I don’t think correct me if I’m wrong
If it was a programmed flight on Litchi, you’re 1000x times braver than me @shane9377
Jeff, I’m guessing it was flown manually using the Litchi app, rather than GO4?
Flown manually .
I prefere Litchi as it slows things down a little . Had to turn the sensors off .
Ah ok get it now
All was done with the litchi app … Honest. I use this app over the go4 app . It was all done in manual . and a lot of perspiration . I tried with the Go4 and it was rubbish , Litchi gave me a more manageble flight .
well done ,good control
Amazing to think a family lived there once and it was maintained and probably loved but is now a ruin! Must be a story behind it!
Great vid, where do you get your music Shane?
There is a story behind it . It was once on the Sutton Scarsdale hall grounds .
It is a public right of way now . The path runs straight past it .
The music was from independent musician but i usually write and play my own music .
It was all done with the Litchi app .
Why can’t it be done with Litchi ? I always fly with it
what i meant using waypoints
obviously that is not using waypoints
Haha. Nope .
Manual flying .
