Turned a pretty uninspiring 180 panorama of an abandoned lime quarry near me into this nifty Little Planet.
Personally I love how it has come out, but each to their own.
I’ve not done one of then yet…but I’m inspired!
I’ve moved it over to #panos.
You should look at Interactive 360 Panoramas - How To so that you can post it as an interactive one.
It earns you the Birds Eye Viewer Badge for your profile, too.
They are simple to create really you just need, IMO, the right subject.
I have an interactive vesion of this over on Skypixel so at some point will post a link to that or migrate so thanks for the subject move and also for the pointer.
So rather than post a new thread - here’s the link to my interactive 360 from this location. Not sure how this will work so if it doesn’t then follow this link.
@stubbyd
Hi the link works fine, and the image is good, only suggestion would be to go quite a bit higher, around 50m or so then you will get a more interesting shot showing the landscape around the quarry. I use kuula.com which is a similar thing to Skypixel I guess.
Have a good weekend, I hope the weather will be good for flying.
Thanks @SkyJumper - until I joined here I had no idea about Kuula but will check it out.
And thanks for the tip, this was one of my very early tries so no real idea what I was doing but it works for me
