Just picked up a second hand p4 and on my first video attempt with it I could see that the image was iffy - it was flickering almost like it was struggling to auto expose? any way when I got it home I notice that anti flicker was set to 50hz, so I changed it to Auto and did a quick test and it looked a lot better - is this likely? or have I brought a lemon? here is the flickering 50hz example
Apologies for the link- not sure how to embed yet!
First thing I’d check is if it happens if you take a video with it stood on a table in the garden and with the motors not running.
If it’s not apparent in that, then I’d suspect that it’s either interference from the motors.
If it’s still apparent, then some other internal interference - the transmitter being the most likely culprit, but that might only because some screening of the video cable isn’t doing its job.
Shot in the dark but what are you using to read the card I can’t import on my air 2 iPad as it can’t handle 4K because it’s 10 bit ok in 2.7k as only 8 bit make sure your pc or iPad or what your using is capable of playing 4K mine I jerky on my desktop as its old like me lol just a thought mate if your pc is old then it might not be man enough try filming in 2.7k and then se if better cheers
Cool mate not up to speed on tec but just my own experiences must get a new iPad or they say update out on 17 sept see if makes a difference cheers have a good day
I see what you mean about the image quality but what a nice place to fly!
Just a random thought from someone who knows nothing… Did you have the camera settings a long way from neutral? Maybe it was struggling to get a decent image with the camera being set to take very dark or light pictures.
Yes i spotted it straight away while flying using ipad mini 3. With the sun hood fitted and at tge time thought it was the transmission and it would have ok on the sd card. But it was exactly the same
