My first proper edited video. Would appreciate feedback guys and gals, please!
Chris
For a first edited video this ok. Only suggestion would be to significantly shorten the title and music credit.
Thank you
Good first video that @chris.manley.
I’ve had a few weeks on the broads over the years and almost exclusively used Herbert Woods whos yard features in the video.
I’ve never seen it this high ever. Wonder is this something that we will start to see more thanks to global warming.
Good first edit and interesting subject with the high water levels.
If there were anything that I would focus on to improve on the next one, they would be
Try to avoid re-composing mid-shot as it can look jumpy.
Use some other types of camera movement to mix things up a bit.
Half the length of the video, to around two minutes by reducing the length of clips or taking out anything not really adding much. You can tell the same story in a shorter time which is more likely to hold people’s interest.
Thank you so much for your feedback. All very interesting points and I will shorten the next one.
I actually thought it was a bit on the long side.
Kind regards
Chris
