Propeller life
Just after some advice - how often do you tighten and replace the propellers? I have done around 3 to 4 hours flying maybe more in my first week and need to check the screws I reckon. The props look ok but I have noticed some very slight surface marking on the edges.
How often should I change them? They have not touched anything other than a very light slicing of my raspberry bush leaves earlier this week (very thin leaves and minimal impact).
Do the screws loosen at all? And presume when changing it is obvious what blade goes where?
@Pirbright_Drone weā€™ve moved your post to an existing thread on this subject.
Every time I crash, which is about every month or two.:woozy_face::woozy_face:
However I do such a good job of that, DJI always send me a set of new props (attached to the replacement new drone) :joy::joy:
I used to check before each flight. I only check every so often now, or if I ever let the props hit something. Never had a screw come lose, yet. I only change a prop if it has a nick on it.
Just posting about todayā€™s trials and tribulations. Found 30 mins to head out to the local spot with the drone as I have been harboring a video idea for weeks and decided I had to get the footage needed to make it work. Thatā€™s uploading so will post later in the video section.
But I slipped off the landing pad twice today, causing the props to stop as they were winding down having landed. I have flown it and there is no adverse outcome but it happened twice and I wondered how much of an issue it is for the drone when this happens. On each occasion I however over the landing pad and lowered onto it, however when landing it drifted slightly and when it touched down one of the arms went off the mat into the grass. The land was a hill so it caused the props to suddenly stop on each occasion. I have wiped them all off with a damp cloth and canā€™t see any damage, I presume this is something that they are designed to withstand. What level of marks / change to the props would make you consider swapping them out?
@Pirbright_Drone weā€™ve moved your post to an existing thread on this subject again.
I think landing pads are supposed to be laid out on flat, level, ground, and it may be that the hill is causing your problem. If you canā€™t get the pad reasonably level, Iā€™d suggest manually landing the drone by coming in from the downhill side at an angle, so that the drone is descending and moving forward as it lands, and shutting off the props with the sticks immediately, as opposed to coming in vertically in an auto-landing.
If the drone still slips of the pad, thatā€™s a nuisance but there will be no damage to your props. You might be able to get the pad reasonably level if it is made of stiff material, couple of stones should do the job. Otherwise, Iā€™d suggest palm landing, but Iā€™ve got a sub-249g drone and might not be so keen with something bigger!
Thanks yes levelling the pad is a good idea. This was manual landing - out of interest how do you stop the props when they are spinning on the ground? I started them up then changed my mind but couldnā€™t stop them so took off and landed again. Is it the same down and in / out with the sticks?
Yes :+1:
Edit : forgot to say only do it when the drone is on the ground or it will fall from the air, just saying !
And if you have it turned on in the app you can do it mid air too.
@TheJohnster donā€™t try, but if you do please make sure you are recording
Didnā€™t they change that on DJI drones in the end? So you can only cut the props if the drone is in an error state?
The cut out is still there in flight,
Brilliant :rofl:
Omg so you can cut them and fall to your death? Seems madā€¦ why?
Well the main reason my thinking is - if your in the way of an emergency ie helicopter - plane or whatever & you canā€™t get out the way quick enough, you either cut the motors lose your drone & shed a little upset or shed a big upset & never forgive yourself if you brought down manned aircraft ā€¦. I know what id rather do !
:+1:
Emergency
You can restart them too same way there are some videos on the tube of folks doing this
CSC
@Pirbright_Drone i donā€™t advise but have a watch of this,
Sorry to dissappoint, Chris, but Iā€™m quite capable of crashing unintentionally, like normal people do, thank you very much, and Iā€™m not in any rush to do it deliberately!
If you did stop the props in mid-flight and demonstrate Newtonā€™s First Law, how would you restart? Surely, the drone will be at too much of an angle for them to restart as it tumbled downwards; a drone cannot glide like a fixed wing aircraft, and all control is lost irretrievably, isnā€™t it? I mean, I watched the video but that guy was lucky; no way Iā€™d chance it just to see if it could be done!
Honourable Dronicide in the face of an immediate collision that could cause more harm than a drone crash is the only possible scenario in which Iā€™d ever consider doing this, and hopefully I will never encounter such a situation!
Watch the video :point_up: CSC
For whatever reason, your drone is drifting out to sea, or heading towards a large crowd of people and you need it on the ground asap. Cut the props.
