Just wondering how this will be with V01.03.0500 released today
The new firmware looks good for the mavic 3 series.
What did the release say the firmware is for?
What’s New
• Added Vision Assist.
• Added AR Home Point, AR Return-to-Home Route, and AR Aircraft Shadow.
• Added D-Log M and HLG color modes for the tele camera.
• Added Night mode in recording mode for the medium tele camera, supports 4K 24/25/30fps.
• Added QuickShots for the medium tele camera, including Dronie, Rocket, Circle, Helix, Boomerang, and Asteroid.
• Added MasterShots for the medium tele camera.
• Added Sphere Panorama for the medium tele camera.
• Added Vision Positioning and Obstacle Sensing switch.
• Fixed some known issues.
I am guessing the firmware upgrade on the controller is required for this.
The firmware on the drone won’t affect the RC controller or hack
But you need to update the DJI RC and the release notes say
Overview:
Date: 2023.09.05
DJI RC Remote Controller Firmware: v01.03.0500
DJI Fly App Android: v1.11.4
What’s New
Fixed some minor bugs.
The sins patch is compatible.
DJI RC
Worth mentioning again, but if you have a new RC (not the pro) you must have a version below 0400 in order to install this hack.
0400 and higher will not work unless the hack is already installed. And if it is re-install before you upgrade. Then upgrade, then reapply the hack.
This also does not work on the RC2 as far as I know.
when you are on 0100 install patch v1.4(i had v1.3 so i installed v1.4 over it)
after that i was told you could update to 0500 and after that reapply the v1.4 patch again(did not try yet)
i also read that when you are on 0400 you could try to install v1.4, wait 2 hours and install it again
upgrade to 0500(using dji assistant) and after that install v1.4 again
worth trying if you are stuck at 0400 and you lost the fcc hack
and i will stay on 0100 for now. the only reason for DJI for bringing out new versions is to stop exploit.
al the new things they offered in 0500 like homepoint visible, homepoint route back, drone shadow they did not make it avaiulable for the mini 3 pro and this is really strange because the mini 3 pro should be capable of doing these thing, no extra sensors necessary
Using my previous instructions for the 0400 I have done the 0500 upgrade and reapplied successfully in exactly the same way with no issues at all on my RM330.
Basically just apply the patch again to your existing version, perform the upgrade and then apply again.
Hi all, i am new on this forum and apparantly can not post messages yet. I try to upgrade and now receive a paypal link addressed as @congcc. If i click on it i get a paypal screen with a photo of Kim Yung Un on it. Is that normal N
Thank you, i will give it a try and report back on the forum
We should be charging Sincoder for providing first line support.
Hi @Kweetje, it looks as though you’re quite new here ![]()
Maybe, but it is strange to me to send money to a man with this photo on his profile…’
@SparkyFPV Wayne
I have same credentials as you ![]()
But you said this
Correct, spoke to him on that link, the PayPal is now a new address as above, not the old one as that link no longer works he says, if that makes sense.
No ![]()
