Ok
So the contact is the same, payment address / payment details have changed ?
Now in HKD not USD but it works out same price as before in sterling .
I can confirm the new details above work, as I took receipt of a new controller yesterday !
Readme file is the same, just different payment / details, price is the same ![]()
Hi, i just applied successfully the hack on my rc controller. In the end i decided to work with Rimzler although a bit more expensive. I just felt uneasy about the Kim Yung Un Foto on the paypal payment request⌠Everything worked out fine with Rimzler.
Also worked out well too ![]()
Hi, Are the configuration parameters permanent or do you need to set them every time again ?
Iâve not really messed about with those but, I have put it in to Atti mode as per the readme txt, thatâs permanent unless you turn it off ( Atti off ),
Maybe someone with more knowledge of yr question will be able to answer. ![]()
Iâll give it a try.
They all stick until you either upgrade the firmware or disable them.
Great, thanks for your answer !
RC 2 patch is now available from sincoder !
COMPATIBILITY
DJI RC V01.03.0100 (NOT LATEST)
01.03.0400 AND LATER DONâT WORK (1) AND ARE NOT DOWNGRADABLE
â
DJI RC PRO V03.02.0500 (LATEST)
DJI RC 2 V02.00.0100(LATEST)
MAVIC 3 - PRO - CLASSIC - MINI 3 PRO - MINI 4 PRO - MINI 3 - AIR 2S - AIR 3
â
ALSO AVAILABLE FOR RM500 - RM510B - RM700
Sincoder just messaged me. He is doing fcc hack on RC2 now for ÂŁ40
Talked with Sincoder, did the job on RC2 from Air 3, took a few tries and some chat with him but in the end is working. For now I have used only CC US and led off. I have some questions⌠as we know dji remote can be tracked to operatorâs location but if you take off, update rth and then use rcgps off, doesnât than mean now you canât be tracked anymore but still use rth on that first point as a safety? As for the second question, landing on/off is only for mavic 3?
I canât edit my message but as an observation, even if Iâm using FCC US the auxiliary led and aircraft front arm led menus still will not be available in the safety options.
Hi @ycodryn, it looks as though youâre quite new here ![]()
Might be wrong, but I thought that as long as you updated on 1.03.0100 you could then upgrade to a later version and still mod.
However if you start at 1.03.0400 you canât.
Yes I think that is correct, for now anyway
NEW patch release RC (RM330) control with firmware higher than 01.03.0100
RC firmware supported: 01.03.0400 > 01.03.1000
If the above video isnât self explanatory enough, I google translated and tweaked a set of Spanish instructions.
Instructions.pdf (2.8 MB)
Note: unlike other hacks, this one requires you to delete a 900mb file from the RC, copy a hacked 900mb file from the SD card back to the RC ⌠all within a 25 second window, or you have to start all over again ![]()
EDIT: the instructions are incomplete, please use the instructions further below.
After spending some time with this new hack installation process, these instructions need to be rewritten. The above set arenât mine, they are merely a Google Translate version ⌠and do not capture everything, trust me ![]()
Iâll document how I did it in a bit. Put it this way, Sincoder has had his ear bent these last 24 hours. I will also send him my set of English instructions to distribute to other folk (if he wants to), so they donât fall fowl of the issues I faced.
But good news, I can vouch the FCC hack works for FW above 01.03.0100 on the DJI RC.
Dare I ask how many hours youâve sunk in to this one Chris?
Nicely done though ![]()
