Hi guys
Having a problem getting my St16s to read the memory card when in flight mode 2.0 so camara won’t take vids or pics it’s fine in android I can read right and uncounted and mount it but as soon as I try and Evan read the card in flight mode it’s just grayed out I have tried 3 different cards Evan the scan disc one that came with it but no luck anyone solved this problem?
have you formatted it using the drone . and also check the max capacity the drone will take
Yes done that in the controller as the typhoon h plus hasn’t got a memory slot on the drone all done from the. Controller e
Scratch that just found the slot for camara memory card lol what a plonka
Someone didn’t read the manual.
Didn’t get a manual with this one but have d/loaded one now
Don’t worry, happens to us all.
Remind me one day to tell you about my Toshiba laptop volume control
Steve
Just to point out there is a memory card slot in the underside of the camera. You may want to have a quick look I have put a card in the st16s controller just because
now that’s well hidden. im not surpised you didn’t find it
