Yeah they face the same way. Weird that. So in terms on the way they fit the motor they upside down from the traditional top mounted. Then add in props out or in… Probably easiest to look from above as you used to with a traditional one
You up and running now mate
Good will have to share some footage
Maiden Fly. (Forgot to take batteries - so only have one lipo one me! )
Not bad even in 14mps winds. Manual hover test:-
Looks good what camera do u have in it ???
Just trying gyroflow data (after watching football)
Is the footage from the walksnail cam ???
Well convert to a low-quality gif.
Here the footage, high definition from onboard recording (but smoothed via gyroflow):-
Cracking footage if walksnail was about when I started id of probably gone for that. Are they cheaper than vista and V2 goggles??
A little cheaper. 5-10%, but I think DJI is crisper. DJI also easy to get a pre-built.
I do want to get the Walksnail Avatar HD Pro Micro Kit (Dual Antenna) (32GB) | HobbyRC UK and have low level light. I dont think DJI does a low level light.
I think there’s a couple of ôptions with DJI.
Polar vista being one of them. It’s usually only the camera that you need to change
