I had a single wire receiver on it. Just TX from the Receiver to RX on the board. Since I didn’t need the other wire on that UART I used soft serial to put it on another serial port with the LED pin so I could put GPS on the quad. That FC is very short on pads, it’s an F411 and not new.
Anyway it was running BF 3.5.7 (I think). I don’t think it should have, but something odd happened on the RX from the receiver. The packets were not getting through quickly.
In that video I had a dodgy antenna as well. I fixed that and is still performed bloody odd until I returned it to it’s original wiring and config.
Presumably I don’t need to worry about ESC calibration? On planes I do the whole power on with stick up thing, then reduce to zero to calibrate. I’ve never had to do that on quads…?
It’s a BLHELI-32. What config app do I need - there seem to be loads. I have BLHELI Configurator on my machine here (might be a bit old) which seems to connect ok, then when I hit ‘read setup’ nothing happens. I had to reverse a couple of the motor directions - I did this using BF4.3’s nifty motor direction tool which is very cool.
I shouldn’t need to connect to or change any ESC settings just to get up and running, should I?
If d-shot, you don’t need to calibrate.
If running 6s, put the pwm to 24khz. When I went from 4s to 6s, it kept desyncing / cutting out. 24 is good for 4 or 6s
Thisis the default setup for my board, before changing anything.
I soldered the receiver to RX/TX4 because it was in a nice easy place on the back of the board, vs RX/TX1 which is the default and on the side of the board. I turned off the MSP toggle and changed the serial RX from UART1 to UART4.
This a problem? I’ve just reflashed to BF4.2.11 - tempted to resolder the receiver to UART1 just to keep everything as standard as possible.
Odd, the schematic for the board says UART 4 is “Vacancy”… so why did they have MSP attached to it?
I guess in case you knocked the USB connector off… hmmm…
Still I don’t think it should be a problem, however experience tells me it may be worth switching to the default of UART 1 just to check. (as you have done)
After flashing you did say yes to “custom defaults” didn’t you?
Yup, utter muppet. Still, it works, and I can very slowly tweak one little thing at a time in terms of tuning now. Going to do another hover in a sec in the garden with 6S and 7" props, then might take it to a big field tomorrow AM and have a very gentle fly about.
Oh, what a rollercoaster. 6S and 7" props back on, same problem as before. That means it’s the props, since it was also doing the same thing with 7" props and a 4S battery this morning (albeit less aggressively).
Could it be a certain amount of load on the motors causing them to spin up? In Acro mode, they spin gently when armed and it doesn’t take off until I raise the throttle, then it shoots up. Going to have to do some Googling.
I notice when using the manual motor sliders in BF configurator, where you can spin them up on the bench, at very low values they stutter a lot. Say, 1005-1010 ish. In real flying situations I think BF considers a minimum throttle signal of 1050 - raising the slider to about 1025 has them spinning smoothly - so that’s probably not related.
