Has I’m running out of room in my fpv bag I decided to invest in a Tango 2 unfortunately it came when the other 1/2 was in so explained it was on offer hence a Good deal. With that and the fact I can sell my other one means I will more or less break even …
well if this is right then it doesn’t seem so hard fatal last words
Am I right in thinking you can get different size boards as the one above is a nano for something like a tiny whoop?.
So for a 5inch you’d use a bigger board ?? or can you use a nano on any size quad and just put the relevant antenna on according to the size of the quad i.e bigger for a 5inch smaller for a tiny whoop?
It’s not, Crossfire is very well behaved.
Only problem you may have is a double green LED flashing after bind (this is called a ‘ghost’ bind) It looks as if it is bound but IT’s NOT! DON’t FLY like this as the signals don’t actually get through.
You just need to repeat the binding process untill you get a solid green LED. Then it’s perfect
