Thanks for the add 😁
Hi folks, im Kenny, gonna buy my first drone imminently and thought id soak up the knowledge on here :grin:
Hi Kenny @Grizelda and welcome to GADC :+1: :+1:
Hi @Grizelda and welcome to Grey Arrows :wave:t2:
Have you seen our Members Map? You may find some pilots living near you. Feel free to add yourself to the members map too :+1:t2:
Welcome once again!
Hi Kenny @Grizelda You can’t go wrong on here, there are sooo many knowledgeable members.
Welcome to the GADC.
Rod
Hi @Grizelda, Kenny, Welcome to GADC,enjoy.
Hi and welcome. So before you get your first drone. Have a think, what do you want to do with it. What are your interests and most importantlly, where are you going to fly it. The weight of the drone is very important be it sub 250g or above. Above 250g will give you more restrictions in certain scenarios.
Why not look at good to go. When picking your drone pick one below 250g and one above 250g. You can then see the combinations after that to see what you are limited to. Or if you have a drone in mind, pick it and see exactly where you can fly it and under what circumstances.
Hope this makes sense and helps.
Also, if you are a fan of the late night shopping channel, do not buy one off there.
