For severe weather and hostile environment applications my go to tape is self amalgamating tape. It’s very grippy and has survived more than 20 years when used on outdoor RF connections.
I’ve found it useful on tight XT60 plugs as it provides a excellent finger grip when pulling batteries off models in cold and wet conditions.
For exposed electrical connections, such as where you solder your motors to 4in1 ESC’s and other similar exposed solder points I use liquid tape. This provides protection from shorts when you go down in wet grass, and is easy to remove if you need to do a motor swap. It’s also a suitable alternative to heatshrink tubing when you don’t have tubing of a suitable diameter for the wire diameter you’re using.
Just sayin’ Chris, these mothers reach top speed within 1 second. No reason to keep your left thumb up for much longer than that when the next gale blows
£72 delivered from Canada. Not sure if that’s decent. But love the look of the frame. Not sure what “en vogue” means. But if it’s “grrrrr” … then yeah.
