@notveryprettyboy Karl I will stick my 2 pence in!! wonāt Handbrake encode it to 4K
I am just running this too see
Iāve never understood why (a) itās called Handbrake and, (b) its icon is a pineapple and a cocktail.
I see it uses ffmpeg too.
Its for @SirGunner if you find a phone app, heāll love it!
Yeah if anyone knows of an Android App that will upscale to 4K with a half decent result that would be awesome! @group-android
one called āvideo transcoderā
Just tried that and it wonāt read my memory card for some reason
Hey Karl @notveryprettyboy fancy sending me a short .ts file so I can have a play in Filmora?
Try this. But it was done before a beta software update. It may cause problems. If it does, Iāll find another.
Try.zip (33.4 MB)
Use the above link, go to assets and download the zip file Axiom.FFmpeg.7z
unzip to folder and run Axiom.exe
I have it working
I took the .ts file from Karl @notveryprettyboy , it loaded straight into FilmoraX, cropped the end rubbish off, then rendered them at these resolutions:-
I delayed posting these until all HD processing had been completed in YT
Letās see what You Tube does with them⦠you may need to use the settings cogwheel to be sure you are viewing it at the correct resolution
Works a treat Steve
I am on the lookout for a cracked version now
All really good @Steviegeek
I find there are too many ā4K snobsā, most are are watching on low quality shit and couldnāt tell the difference anyway I fancy.
Great job
When you land a plane, it bumps the receiver wire, it goes into failsafe and tries to take off again, regains the receiver link and comes back to life, and me being a complete plank, didnāt realise and crashed. No damage though
Lucky escape - looked to be headed straight for that tree for a bit there !
Buttock Clencher moment right there!!
The only thing I can think of is that it was outside of the 5mtre home radius (6m) so it thought it needed to failsafe.
@Steviegeek had the best idea. Disarm just before landing. Because you canāt disarm when in failsafe
Damn lucky!
