Huy guys, so I bought this drone as I’m a beginner and long story short, I’ve passed through the whole calibration process but the drone doesn’t start. (They ask you to push the joystick to unlock the drone but they stop spinning and doesn’t take off)
Also there’s no Wifi signal coming from the drone and you have to connect to your phone to use the FPV. Is there any way to try to reset it or is the product defective ?
By the way, the battery was fully charged for aver 5h.
The drone uses the 5GHz WiFi band so you need to use a mobile device that has dual-band capability.
If you’re using an Android device with dual-band capability but you’re unable to see the SSID of the drone it might be on a channel that your device can’t see. The majority of Android devices sold in Europe don’t have access to the higher channels that are used in the US. If this is the case and you know someone with an Apple phone or iPad you might be able to log into the drone and change the WiFi channel to one you can see with your Android device.
I can’t say for definite but I would expect to see an SSID named ToySky xxxx or TSxxxxx or similar.
Is there a difference if the drone is switch on?
IE a SSID that isn’t there when the drone is off
