Unable to connect Eachine E520S to Honor 10 Lite
Problem 1.
All calibration completed fine but I can’t seem to find the drone to connect via WiFi.
Any help appreciated… Eachine e520s
What mobile device are you using? I believe it only works on 5GHz WiFi.
Nidge.
Honor
Do you have a model number?
Honor 10 lite
I have an Honour 10 which connects fine with my Mavic Air.
What drone you trying to connect to?
:wink:
I assume you turn the drone on and do a WiFi search
It should connect as the WiFi spec of your phone includes 802.11ac.
If you switch the drone on then in your WiFi preferences wait for its SSID to appear you should then be able to connect to it.
Nidge.
It wouldn’t be faulty would it?
Great bloody start to the world of drones this is
Sounds stupid ,i know, but, you have turned the drone on, and the remote?.
It should then show up in your Wifi settings, as Nidge has said.
Yes indeed so
When you say WiFi settings do you mean WiFi list of available devices
Available devices or available networks. Each manufacturer may label things differently.
Yeah I’ve 20 or do WiFi networks found but not the drone
@Charles1976 your original topic title of "Help!" has been renamed to something more descriptive that will help others find it in the future.
It’s getting sent back to amazon waste of £
Does the drone wifi need to be enabled in some way
Unknown… I’ve tried everything as per instructions
