I watched a youtube video.
Cheers. Already seen that and various others
If you cant find it via wifi make sure that ya phone is on the right ghz and then if so ya drone is not giving out a signal…or search on someone elses phone.
just read up on the honor 10 , from what I have read its not compatible with the 5ghz wifi. if its anything like my mavic 2 pro controller , it has 2 usb conectors, if both are pluged in it wont connect to a phone or tablet
As far as I’m aware all o the Honor 10 range, except for the 10Lite which only has 802.11ac available on its domestic model, work with 802.11ac.
Nidge.
Unfortunately I’ve not managed it surely it would be common sense for manufacturers to provide a lost of compatible drones for phones …
How do I know what drone will work with what phone so as to avoid this again
Mine is the 10 lite.typical
Sorry to see you have had a problem with your first drone m8 hope you get it sorted.
Bit fed up tbh spent hours choosing the dronen only to end up sending it back.
I know what you mean, very disappointing.
have you thought what your going to get next?
Not a clue how do I know it will be compatible prior to purchasing.?..
You could just buy a tablet that will opperate the 5ghz, great little drone by the way.
As long as your phone is 802.11 ac compatible you should be good to go.
Did you not like the Bugs w4?
Apparently my honor 10 lite isn’t compatible with 802.11ac
This link will give you all the specs of your phone
Interesting then why couldn’t I find the drone on wifi search
I think you may have been unlucky.
Perhaps the wifi was faulty from the drone side of things
