Unable to update DJI Mavic Mini (1) Firmware
Thanks, but once you have done one Edit, it will not allow you to edit the same post again!!!
See if you can’t ask a friend or borrow one, if you’ve checked it in the app and it’s showing it’s running the latest FW, I’d say all ok but, I’d still check on DJI assistant if possible.
Again as I stated above with myself, that was all it was, I did try 2 other phones & an I pad, still showed the same but it was all fine. :+1:t2:
