I’ve got an old set of props here, I’m going too WD40 them and stick them in the freezer, although I do expect some freezing as it’s a lot colder. Experimental
Yes, WD40 does freeze . Its freezing point is -81.4 degrees Fahrenheit. To prevent freezing, you should store it between this temperature and no warmer than 120 degrees Fahrenheit.
Maybe right at the the back of my fridge we’re it freezes up, not the freezer
