Now I’ve just got to test what I’ve put together.
I’ve not used this mode before and I’m guessing like others (activetrack) you can just stop it mid flight if needed? I’m unsure on the height of the trees so this might cause an issue.
Yes steve, think I might do that, don’t want to just hit GO and hope for the best. I’ll probably never use this feature again but to test it out can only be a good thing.
Waypoint 2.0 is great. I think you get full sensor protection in that mode, but check.
It produces very smooth footage when varying yaw and gimbal while flying sideways/backwards. Try doing that manually!
