The drone is still in GPS mode in Sport Mode - yes!
It doesn’t kill the application - only the mission that’s been uploaded to the drone by Litchi.
The uploaded mission runs totally autonomously from the app and the RC once initiated.
I tend to use the pause button to stop the mission.
Selecting Sport Mode, or pressing Pause, similarly stops any of the DJI built in things - tracking/POI/Pano, etc … so it’s doing nothing different to Litchi than it does to its own gizmos.
Totally agree with @jonathantozer’s “getting used to it doing its own thing” tips … small, simple, slow mission in a small field that you can easily follow.
It’s still strange seeing it buzz off under it’s own control - this morning’s 1.2km max distance over the sea … etc.
I’ve said elsewhere, before - I totally trust Litchi to do exactly what I tell it to do … I trust my ability to tell it the correct things to do far less.
Using Virtual Litchi Mission (windows only) is a great way to visualise what’s going to happen.
This vid was created in VLM.
Well… seeing as the weathers crap, I’ve been enjoying my time putting together my first litchi mission. Will certainly need to do a trial mission before I put a big one through it’s paces.
There was a virtual mission of a London flyby posted here somewhere. Anyone know how to get a virtual representation ?
If you are on Windows - you need Virtual Litchi Mission (from Mavic Pilots - latest download link always in first post of that thread) and Google Earth.
If you’re on Mac (or Windows) there is a Chrome Browser plugin (also in Mavic Pilots - latest version in 1st post) … and Google Earth.
The VLM program is far better at creating the representation, imo.
In the little I’ve used the Chrome plugin I’ve found several significant bugs that I’ve reported … and they’ve been corrected … but there are probably more I’ve not found - so I gave up on it.
Thanks Dave. Damn - I didn’t need the “want” to get into this ! Keeping me away from work and PfCO course.
Addictive stuff. Man - i’m behind the times on this.
I’ll upload a render of the VLM for the flight above, to the fort.
It’s a modified version of the mission used for that flight (increased distance when circling, etc) … but it still gives you a good comparison as to how VLM gives a very good representation.
(Unfortunately, the fort isn’t in 3D in GE … otherwise it would look even more similar.)
I’ve been experimenting with waypoints on the Mavic 3 Classic. Usually they run smooth with no problems.
However today, I thought I’d be clever, I planned a mission from home then drove out to the location to film it.
Nearly lost the drone.
Totally my own fault. I had plotted only 8 waypoints, but the first 3 were well spaced out, consequently the arc from start to number 3 was massive. I nearly hit a load of HT cables which I normally miss because I took my eye off the screen.
Here’s the video, I’ve speeded up a few sections to show what happened.
Then the drone lost signal half way through and I hadn’t changed the behavior to ignore lost signal and the drone returned home to fight another day.
