Where can I buy r/a short cable?
Hi all. I’ve had a few disconnection issues recently and having searched on here I see many experienced flyers recommend using the USB A slot on the controller rather than the USB C slot on the side.
I’m going to try that, but I can’t find a short right-angled lighting to USB cable anywhere. Amazon have none and don’t know when they will have any. I guess I can make it work with a normal USB A to lighting cable, but that’s at least 1m long, and doesn’t have the right angle connector, so will be awkward.
Any thoughts welcome.
@Jaycee360
I got mine from Amazon, Anker brand, 300mm long and it’s a perfect fit. It’s the quality version with braided covering.
I’ll see if I can dig up some more positive information
Steve :slightly_smiling_face:
What about a magnetic connector?
This Amazon search has a few of the 1ft/30cm ones that @Steviegeek mentions.
(it also has some other sizes - such searches are never perfect.)
Edit: No right-angle ones.
For charging - yeah - but I’m buggered if I’d use one whilst flying!
This is in stock for delivery this week
Highly recommend it
I’ve used magnetic but won’t any longer
On Mavic controllers the USB A slot is FAR safer to use. If you open up a controller you will find the USB C slot is offset for some stupid reason, hence many owners world wide have damaged the connector and then need to spend a fortune replacing the controller. It is also almost impossible to fix this yourself if it gets damaged. It is a fundamental design flaw in having the key tiny, thin C blade offset - no other C product has this offset. For those who insist on using the C, the best option are the magnetic connectors BUT care is needed for obvious disconnect reasons. I use an ANker right angled connector to my iPad mini from the A slot - 100% faultless - the key is to buy quality cables not the CCKO ones IMHO of course.
Many thanks guys. @Steviegeek cheers…I’ve ordered that one. I was hoping for a RA cable but that short one looks good anyway …and comes highly recommended:-)
I’ve just tested the USB A slot with a long cable and it works with no disconnect so far.
Happy flying!
I don’t think magnetic connectors support data do they? Only power/charging? :thinking:
Do I get the solution tick for this :thinking:
:laughing: :grin:
I’ve come across one or two but like @OzoneVibe I would not rely on a magnetic connection when the priority of the data is high. A reliable connection needs to be electrically and physically sound, and a magnet provides none of this.
Nidge.
Nor me.
The wife has a magnetic for her phone at night charge and I think that’s about the only real use for them.
I tried one in the controller side USB port, (for charging only) but the magnet was stronger than the connector retention, useless !
NetDot 12th Generation 3-in-1 Magnetic Cable,Fast Charging and Data Transfer for Micro USB/USB-C Smartphones Sumsung S10/9/8/7/6/Note9,Sony,Google and i-Product(2m/1 pack black) https://www.amazon.co.uk/dp/B07QDYXVBB/ref=cm_sw_r_cp_api_i_iAXIEbA9XB92A
I have this - works perfect with the Apple micro USB to lighting adapter.
AmazonBasics Double Braided Nylon USB 2.0 A to Micro B Cable | 1 Foot (0.3 m), Dark Grey
by Amazon
https://smile.amazon.co.uk/dp/B074VM7J5Z/ref=cm_sw_em_r_mt_dp_U_0ffJEb890R8SA
Rick
