Landed safely, as intended on the roof of my car, stopped recording. Minutes later I went to put the drone away and thought “I’d better stop recording”, retrieved the drone and was in the process of putting it away when I noticed it was recording.
I doubt I’m the first, nor the last, to do this. The learning process continues.
Brake hard and OOPs…in the footwell
A thing called “power switch “ is usually found on drones. In the absence of one, removing the battery achieves the same result
Only if it’s still on the seat before moving off. Recording was turned off and the drone placed in its box on the floor
