Motor wires trimmed to length and soldered to the ESC and heat shrinked the capacitor to prevent a short on the carbon fiber frame.
And retro fitted the top plate to check clearance of the capacitor now that its heat shrinked.
Perfect fit! Happy with that!
super neat!
Big thanks to @Steviegeek for the heat shrink suggestion. Much appreciated.
Coming alone nicely Deano! Really looking forward to seeing her maiden flight
Long way off yet lol Still got the Camera, VTX and RX to wire up. Then I need to connect it to my computer to setup the motors to make sure they are spinning in the right direction setup my modes and configure the quad so that everything matches my radio like stick configuration ect ect. Still lots to do
This afternoons task was to make some motor wire protectors from a couple of old battered 5" props and some good old electrical tape.
All motor wires protected from prop strikes in the event of a crash. When you crash a drone the first point of impact is usually the props and they can bend downwards and when this happens they can strike the motor wires on the arms and they will cut straight through the wires. So I’ve done this to prevent that from happening.
All 4 arms and motor wires protected.
Cheers steve, I can’t take credit for the prop blades as I picked up the idea from one of Joshua Bardwell’s videos
but it is a good cheap hack for protecting your motor wires
Figured I’d weigh my quad along with all the parts that will eventually be attached to the quad to get a rough idea on what the overall take off weight will be once its complete.
There are a couple bits missing like a non slip battery pad that will be added so it is only a rough idea on the Total Take Off Weight.
If you don’t mind what’s the tally in parts up-to price wise
Just over £200 mate
although I have selected premium parts
I’ve got a lighter lipo strap if you want it.
Actually I’ve got 2 of them lighter lipo straps
that was just the one that came with the frame lol
Tonight’s task was to build my TBS VTX and RX mounting board. This had some pretty challenging soldering due to minuteness of the connections.
All the components laid out
VTX and RX soldered to the mounting board
Adding the wires that will eventually go to the flight controller
After this I think I need a break so that my eyes can re adjust to seeing normal size things again! Lol
Thanks for all the updates and photos @DeanoG60
Following this thread with interest.
Tonight I finalised my wiring and connected my VTX/RX mount board to my flight controller, also wired up my FPV Camera to the flight controller as well. This pretty much finishes the wiring and soldering.
Looks like a birds nest of wires lol
Also added the TrueRC Video antenna and my Crossfire antenna.
This pretty much finishes the actual build of the quad.
I’m currently waiting for a smoke stopper to be delivered. This will stop me from blowing my boards if I’ve accidentally shorted something or got my wiring wrong. So I won’t be powering it up until my smoke stopper has been delivered. I’ve still got all the betaflight setup to do yet so I will be sure to post some screen shots of me setting up the quad in betaflight. Need to make sure that my motors are spinning in the correct directions and setup my OSD (on screen display, what info I will see on the screen in the goggles when I’m flying) also need to make sure that my stick inputs are correct last thing you want when you fly is to pitch forward and the quad rolls to the left lol
Hopefully my smoke stopper will be delivered tomorrow and I can get on with the setup
almost finished and I’m itching to get it in the air
and with it being less than 200g I can legally fly it down my street
That’s some nice neat soldering!
Make sure no wires vibrate onto the gyro chip
Looks like a great job you’ve done there Deano
What is a smokestopper? I reckon you should trust your skills and just power it up mate
