Thanks Steve. I needed to use loads of holiday up so I have time to mess about.
If anyone builds this, I can give some help.
I just tested it in the back yard and it didn’t work! But I had the magnetometer configured the wrong way round (its the opposite to Inav for some reason). It follows my 5" now.
I’ll strap a camera to the tracker and try to get some video later. Hopefully tracking my quad or a plane.
There is a slight possibility that the mag needs to be slightly rotated a few degrees. I wont know until later.
Having problems myself
My mag was the wrong way round and the pan servo back to front. Easy fix.
But the latest crossfire fw doesn’t give altitude as far as I can see unless I try to find it. Altitude is available on fw 4.11, but the mavlink is not stable.
I’m going to reload the latest fw and try to find the altitude.
Back in the days, I had to set my tracker facing magnetic north, once the tracker had enough GPS, then set that position as the zero heading which tied GPS and Magnetic North.
Here is my first attempt at getting this to work……I abandoned it in the end as I spent too many a weekend at it instead of going “shopping”….
Wrong video but I’ll leave it for your entertainment…
