can anyone send a pic of how the battery leads look on the speedy f405 stack. i understand the battery plug but can not seem to get my head round what i need. part link to hobby rc for parts would be good.
I’ll send you a pic of mine. Oh wait…
But I’ll do you a solid
it’s the least I can do after all your help trying to find my wing.
If you need any help just ask
and what do the other 2 leads on the board do
ESC power connection for the motor.
so what does that mean .this is the bit i do not understand
ESC stands for Electronic Speed Controller. it’s a separate board that is used to send instructions to the motor.
I have this one in my Mobula Wing (the pic above)
but as a beginner builder I’d suggest buying a PNP Wing Kit as this will come with the correct motor(s), ESC, Servos and prop(s)
i got the PNP so i do not need to put one of them in cheers for the help.
You will need an ESC if it has a motor.
What kit did you buy? got a link?
So yes that will come with an ESC it will have a red and black wire coming off it and 2 thin black and white wires twisted together with a 2pin connector on the end of it and on the other side there will be 3 wires
i have not opened it yet so i may need to LOL
Have you decided if you’re going to FPV it?
i will i am buying something every month towards the build, any tips at work also going towards it to.
Decided what FPV system you’re going to go with?
Have you got the wing already?
DJI o3 air unit not bought this yet and need to see if fully supported on this system.
yes got a few bits may never fly but started the dream
Wow… expensive lol Yes its compatible.
