So it turned up today. Not had much time to play but did manage a quick hover in the garden. Suspect i need to look into settings but if I’m stool behind when I turn the controller left the Avata goes right
That doesn’t sound right🤔.
Have you calibrated the controller? Even so, it shouldn’t be behaving like that.
Give it another go see if it happens again.
And I take it before launch the Avata was facing away from you?
Was the Drone/camera facing you
No, was definitely facing away, going to the recalibrate today as that was the only thing I could think of that could have caused that behaviour.
I’m still on the fence, Avata or Mavic 3 Pro…
I’ve found charging a bit of a faff, well getting the right power supply to do it anyway.
Luckily I had a spare 65w laptop power supply, which does the Avata batteries and the Google’s 2, but it appears that you need a different one for the motion controller.
Anyone else suffer from motion sickness using the DJI simulator?
Yeh a bit, you get used to it.
If your using a simulator, give Liftoff a go, I found it a hell of a lot better than Dji virtual Sim. I have a blag copy, but I think you can get it for only 20 quid download
Liftoff, Velocidrone & DRL are all worth a go - although the dji sim is the only one I can get to work with goggles - you’d probably want to get used to Acro on a sim, before doing FPV in the wild!
Has anyone used any 3rd party antennas with Avata and V2 goggles? (not goggles2)
I’m looking for something that doesn’t need screwing/unscrewing - every time I fly!
Looking at iFlight Crystal or Lumenier Duality HD Stubbys - but not sure about compatibility with Avata.
Thanks for any suggestions.
I managed to get a preowned copy from Music Magpie for £6.50 for PS4.
Copy of Liftoff that is
Related thread from December over here Wayne:
