DJI Fly - App updates and download links
I haven’t updated the firmware on my controller, nor have I updated the firmware on my Mini2 in quite sometime. I suspect the EXPO ability is embedded within the flight controller as this is how it’s done with other multirotor type models, eg the settings are changed in Betaflight/Cleanflight/EmuFlight/INav for the racing/freestyle guys and Ardupilot for the geeks.
For traditional RC fixed wing (those without flight controllers the changes are made in the transmitter because there’s no other way to do it.
@Nidge can you just check in the app what versions of firmware you are running for the RC and the Drone
just so we know
Cheers,
Wayne.
I’ve just put the latest update on my huawei tab and updated the RC and mini2 firmware. Going for a flight shortly , hopefully the connection problem is gone.
I will do when I get home.
Let us know Joe
OK here ya go, @SparkyFPV
Aircraft firmware is 01.03.0000
RC firmware is 04.11.0016
The drone is up to date, and the RC is not, I wonder what the RC upgrade is for?
If running Dronehacks it is probably best not to update
Two batteries down and the mini2 flown as high and far as legally possible. No connection issues or loss of video feed, got a bit laggy a couple of times but only for a split second. That was on the Huawei mediapad M5, android 9
@Nidge This is from the guy who writes the Dronehacks software referring to the RC update
bin4ry
2:33 PM
it will most likely not affect the hacks, but i recommend against it. i have only bad experience with updates in general and more specially in RC updates. also the new rc-n1 rc update i heard reports that the drone and RC randomly disconnect (but only got that info on some air2). so i advise as usualy against any update if there is no realy reason to do it.
Thanks for the info, Wayne. I only recently performed the DH to my Mini2. I also have enough history with DJI to never install a FW update until the “DJI can’t do any wrong” fanboy brigade have fully tested it beforehand.
Thanks, Joe for the info :+1:
Just done a test indoors with My Mini 2 and the Huawei M5 lite with the latest fly app version1.5.4
And like magic, it works, and it seems to be working ok. other than a very slight lag it seems good, will try a longer range test when the weather improves @PingSpike no need to get an iPad anymore :wink:
Dronehacks works fine as well :slightly_smiling_face:
The Expo rates is a good feature and work’s well, but I don’t understand why you can’t adjust them in Cine mode :man_shrugging:
Surely that’s the best mode to make the sticks less sensitive
@Nidge have you any idea why?
Good news mate, that’ll save you a few quid.
Has there been a change at DJI HQ?
It seems that finally DJI have pulled their finger out and sorted out the Fly App for Android
The Drone I am using is the Mini 2
For months now, update after update wouldn’t work on my Huawei M5 Lite with problems after problems and the only way to get a reliable connection was to use the April version 1.4.2 or lower
I have flown 6 batteries now on the latest version (clean install) 1.5.4 and I have had no issues, none! All other apps were forced closed and aircraft mode activated
Today I did a range test and at 1.2km with no problems, I tried in CE and FFC mode, recorded video and took pictures with no lag. The app never crashed everything seemed to work as it should.
The app is more responsive and is now on par with using my iPhone, it really just works as it should
Also, Airdata uploads the media files which is another bonus
Happy Days :grinning:
What drone did you fly @SparkyFPV ?
It’s a Mini 2 @DeanoG60 thanks I have edited it
I was just wondering, since all the new drones have been added to the fly app I get proper crap range on my OG Mavic Mini now. Been wondering if DJI have done it deliberately to force the upgrade to occusync :thinking:
Worth giving the Drone Tweaks app a look re FCC mode @DeanoG60
Give this version a go, do a clean install, I even deleted the DJI folder after I uninstall the old version
Yeah I was thinking that, hence why I asked what drone it was. Knew you had a mini but couldn’t remember if it was OG mini or Mini 2.
