Reason according to Rick from drone valley is that it goes into low power mode and turning off WiFi and Bluetooth helps with less stress and overheat sensor.
Found the sideways toggle I had obstacle avoidance actions in brake mode which does not show option, it has to be bypass to see the disable sideways flight toggle.
Loaded update to controller will try today. It is my understanding the compass error only affects the RC Pro Tx. Those using the RcN1 and smartphone are OK.
Referring to the controller supplied with the mini 3 Pro with built in screen… The compass now works very accurately. Also noticed the camera when angled fully down for landing flips up just before touch down, like the mini 2. Sure it wasn’t before. Technical replied to my email and added that in the update the transmission signal has been “enhanced” again and the vignette thing in photos corrected. Don’t think they were mentioned in release notes?
This is what I was emailed… I only ever read the notes on the app update before deciding!
DJI Technical Support.
As per checking on the DJI Mini 3 Pro release notes, the latest firmware version update/release below, the fixed issues are stated as follows. We are so sorry for the inconvenience, the compass issue was not mentioned. However, the anti-interference ability and the transmission distance of the image transmission system has been optimized in this update.
FIXED ISSUES:
Fixed issue: the videos recorded in some scenarios in D-Cinelike flickered.
Fixed issue: when selecting intelligent flight modes in portrait mode, a false prompt appeared on the DJI RC remote controller or an Android device.
Optimized the vignetting effect
I just had a chance to use them on my vacation. I haven’t checked the footage yet, but in the preview, they look neutral (no colour casting) which is what they are supposed to be. They are easy to fit and attach firmly so there is no danger that they’d fall off. Only ‘negative’ I have found so far is that the case is too low to close when you place the original filter frame in it so you either have to keep the original separate or leave the filter case sligthly open.
Once I have time to go through the footage, I’ll let you know if I spot any issues.
