I bought it separately
Interesting, I haven’t seen them being sold individually, then again, I haven’t really looked either. How much was it? The 6 filter set was £54.00.
I already have a set of ND filters
The Mini 3 can now be flown with the Mavic 3 Pro Controller
Wondering how that will affect the range.
What as in you think the range will improve?
Would have thought so with the external antennae
Mavic 3 Pro ?
Mavic 3 - pro controller
This chap
Now works with the Mavic 3, Air2 S and Mini 3 Pro
Mini 3 works great with the RC pro controller plus repatched for FCC also👍
Friend of mine has flown it back to back with the Mini RC and there is zero difference between the RC Pro and the Mini RC.
He flew 16000 feet with each one before RTH kicked in.
Up or out o;)
out
more good news as well I will WhatsApp you
Is that via sincoder?
Assume FCC?
Yep
I’ve found it depends on where your flying it. If its out in the country your mates test tallies up, give or take. Around where you’ll get interference, built up areas, WiFi signals, I’ve found the Pro to be miles better. Both controllers tested in FCC mode. I tested the mini 3 out with the Pro early doors this morning, out where I’ll normally test, knowing where my signal normally drops, and it was better than the RC. It is what it is, anybody want to buy an RC controller? ![]()
£250 v £850 is what it is ;o)
