mrsparky:
Secondly, when you first activate the Neo you need a phone/tablet with both mobile data AND Wifi turned on. That’s because the neo is using the Wifi, but the app needs to connect to something/somewhere online. Plus you need Bluetooth, and location services on as well.
The second problem is it appears that the Neo needs 5GHz wifi to make the initial activation, 2.4GHz won’t cut it. Nor can you easily change to 2.4GHz just using the app, but you can if you have the controller.
These problems usually happen when your mobile or tablet (like mine) isn’t that new. The solution is to buy/borrow a newish phone to do the setup, then after activating the neo you can use a device without mobile data.
Like personally I used a samsung galaxy S24 to activate, but I fly it using an ipad.
Go back to the very start, using your S24. Once connected and flying as it should, go back to pairing with your old phone. Your old phone possibly doesn’t have the 5GHz wifi required to get things connected
Yea that’s the problem! Also remember that 5ghz must HAVE both mobile data and wifi turned on.
cant afford new phone so im selling it £250
