Think you might need a little boat. Looks like about 50/60m from the edge of the water.
We’ll appreciated , my mates got a little boat I’ll keep you posted many thanks for your help
Edit: how accurate are the or is the data would you know , once again thanks
Should be able to locate it to 2 meters radius if it’s good gps data
Have a walk round you might find a carp fisherman with a remote control bait boat to take the line out 60 mtrs and can drop it within a few feet past the spot let the weight on the end sing to the bottom and real in a few goes and you should hook it
Or even use a drone to take a line out take a look at drone fishing on you tube
Thankyou
Thought I’d add this as to weather it matches up with all the locations and data I’ve added in the hope just to drag it out , if not it’s fine , thanks all for your help & input .
Thanks Wayne , am I looking at the very end of yellow line mate ?
Many thanks
Ah ok mate I’m with you , would you know the distance from land to water or location roughly , I’m thinking waders and a couple of grapple hooks
Sorry or best shortest part / way to exit if that makes sense
If I’m reading it right in or around that triangle ? 34 being yellow 35 being red , I take it red is the final loss
Ok so about 100 odd feet out , so near but so far , I can get to that spot easy just not sure how deep it is , I’ll find out tho !
121 feet to be precise , and on this first image here in regards to the other ones posted this one is my best form of exit / location if it’s to be possible , am I reading that correct , many thanks
