I’ll start by outlining my approach and parts selection.
The smallest motor I have is a AF204 2910KV which I originally bought for my Mobula wing. I was going to use this but having seen Karls @notveryprettyboy two motors in the wings it’s a much better option, as FPV camera can go in front nose. Dur… why was I thinking just one ![]()
So as I need two the same now I’ve chosen T-Motor F1103 8000KV which suits either 2S or 3S (link below) and takes the small 1.5mm push-on toothpick props. Two motors means I can follows Karls lead and setup differential thrust, with this and the wing surfaces set up as Elevons I don’t need to do the rudder, it should control like a wing.
I’ve got some small 20A ESC’s in my spares box so I’ll reuse two of those. I did originally think of using two 18650 cells but not sure if 7v would be enough, then I thought that some flat pouch Li-Po cells taken from an old battery would package better, maybe under the wings, so jury out on that at the moment. (could even use a 2S Tiny Hawk pack)
Smallest servos I could find in stock anywhere are HS40’s made by Hitec, ordered two (link below)
I intend to bury those in the wings, at 8.6mm thick I’m hoping they will not stick out.
As I’ve got a ZORRO ELRS TX coming (stuck in HKG security ATM) I’ve bought a tiny EP2 receiver (link below), the one with the onboard ceramic block antenna, so will be learning ELRS.
It’s mine so IT HAS TO HAVE GPS, which means a FC. I’ve got some older F3/F4’s in stock, will look tonight and decide what I’ll use.
I’ve got a couple of small FPV cameras in stock also some basic 5G8 VTX’s, not cutting edge, bought them in my early days of doing this stuff but at 100mW or maybe 250mW should be plenty, These little planes are only fun park-flyers
I got my plane frame last night so will be studying it tonight
More tomorrow hopefully
Steve ![]()
