Help Needed - Transferring photos & videos from RC2 internal storage to laptop
Hi there! Before you post, have you selected the most appropriate category for your new topic? :thinking:
I need help !!!
I recently purchased a Mavic 4 Pro, and for the life of me cannot work out how to get the pictures and videos that are in the RC2 internal storage to download to my lap top. Is there anyone out there that can talk me through the process please?:rofl:
you want the footage off the Drone not the controller
You can just plug it into your laptop - power it up and its a removable drive or take the SD card out and use a card reader.
Or via the fly app on your phone you can do quick transfer to wireless send the video / photos from the drone to your phone but best way is via your laptop.
The stuff on your controller is low res stuff and you will need to plug it into the laptop and if your on Mac you will need some software that can view Android devices.
Another slow option would be to bluetooth the files to another device.
To transfer screen recordings, flight logs, or media files from a DJI RC 2 controller to your laptop, use either a direct USB-C connection or a microSD card. [1, 2]
Method 1: Direct USB-C Cable (Easiest)
  1. Power on your DJI RC 2 controller. [2]
  2. Connect a USB-C data cable (ensure it supports data transfer, not just charging) from the controller to your laptop. [2]
  3. Access the files based on your Operating System:
  • For Windows: Open File Explorer and look for the controller under “This PC”. You can directly browse the internal storage or the inserted microSD card.
    • For macOS: Mac laptops will not automatically recognize the Android-based file system of the RC 2. You must first download and open a third-party file transfer utility such as OpenMTP or the Android File Transfer app. [2, 3]
  1. Locate your files:
  • Screen Recordings: Navigate to Internal Storage/Movies.
    • Photos/Videos (Cache): Navigate to Internal Storage/DCIM/DJI Album or Android/data/dji.go.v5/files/media cache.
    • Flight Logs: Navigate to Internal Storage/DJI/dji.go.v5/FlightRecord. [1, 2, 4, 5]
  1. Drag and drop the desired files to your laptop’s desktop. [2, 4]
Method 2: Via MicroSD Card
If you have a microSD card inserted into the controller, you can use the built-in Android file manager to copy files over and then plug the card into your laptop. Users on Facebook groups widely agree that this is one of the most reliable methods if a direct USB cable fails. [6, 7, 8]
  1. On the controller, double-swipe down from the top of the screen to open the system menu.
  2. Tap the Settings (Gear) icon.
  3. Go to Storage > Internal shared storage.
  4. Tap Music and audio (even if it says 0 Bytes), then choose Audio files—this acts as a shortcut to open the full file browser.
  5. Tap the three-line menu (burger menu) in the top left and select Videos (or Images) and open the Movies folder.
  6. Long-press the file you want to transfer, tap the three dots in the top right corner, and select “Copy to…”.
  7. Open the side menu again, select your SD Card, and tap Copy.
  8. Turn off the controller, eject the microSD card, and insert it into your laptop’s card reader to offload the files. [1, 4, 6, 7, 9]
Are you trying to transfer high-resolution drone footage, screen recordings, or flight logs? If you are using a Mac and running into connection issues, let me know so I can help you troubleshoot.
[1] https://support.dji.com
[2] https://greyarro.ws
[3] https://app.airdata.com
[4] https://www.youtube.com
[5] https://greyarro.ws
[6] https://www.youtube.com
[7] https://www.youtube.com
[8] https://www.facebook.com
[9] https://www.youtube.com
Shameless google c n p ;p
There’s probably some ironing in AI quoting existing GADC forum topics as a reference.
People will be going round in circles.
… ever decreasing ones until you finally disappear … (oozlum bird) !
Thank you to everyone who helped on this subject,especially Nik469. I believe I have now worked out how to download Videos & Photos to my laptop. I also own a Mini 4K pro drone and had no problems with this, I don’t understand why the Mavic caused me so many problems. Just a bit of a Luddite I suppose,:rofl: :rofl: than you all once again.
Cheers Steve.
#irony :wink:
There’ll be some of that stuff in there too :slight_smile:
