I have (finally) had a bit of a stock check and I find that the Inspires appear to have been breeding. So I have a couple of Inspire 1 aircraft for sale:
One original with the spin-on self-tightening propellers (a set of four used and three new pairs). There are also a load of propeller safety clips to go with it. It has the Pro X5 gimbal mount which takes either the X3 or the X6 camera and the leg extensions that form part of the pro package. I can supply that as a barebones package or add most of what you need - controller, case, batteries
Similar for another I, this time with the gimbal mount mod and the leg extensions to bring it up to Pro spec in the X5 department. The motors have had the prop mounts updated to take the 1345T quick-fit props - I can supply a set of these and spares if required.
I’m dismantling another Inspire 1, with an X5 mount (that’s worth £100 on its own) Motors with 1235T adaptors, good booms and arms. Bodywork has been painted. All parts available.
I also have some white bodywork, some arms, wiring and odds and sods. PM me with any requirements.
If I have to put the stuff up on eBay it will be more expensive to cover their fees, PayPal and the general annoyance of having to photograph and upload the listings!
