I’m flying a Mavic 2 Pro commercially for TV broadcast in the UK, but every now and then the image is black at take off.
I’ve mostly noticed this in flying zones that DJI gets a bit nervous about, even though I self certify that I’m authorised to fly, and have the required permissions from Air Traffic Control. However, it MAY have happened at other times as well - I’m not sure.
Couple of full resets on the drone and the controller and the image returns, but does anyone else have this, or know what I’m doing wrong please?
You’ve lost me, but it sounds like you mean there’s a loose connection?
I’m sure this could be it, but normally this happens when I’m trying to mess around with the unlocking license…I start with an image, but then it goes while I’m unlocking!!!
Just recently I too have had it on my Smart controller much the same when you do a self unlocking, Ive had to reboot both the Smart Controller and the M2, it still records photos and video but you get a blank screen whilst flying - not good
Assuming you aren’t using a Smart Controller, have you tried using a different cable between your controller and phone? I had this a few times when I tried using a (cheap) cable I brought off t’internet. Swapped to a new one, all sorted.
Also, just to clarify - when you say the image is black, do you see anything on the app (like the battery, mini-map, etc) or is the whole screen just black? The cable problem caused the latter.
I have had the same problem. Just wait for checking for firmware erosion etc.to complete then open go fly. Works every time for me if I remember to do it
