been looking at desoldering stations (think hot iron sucker)… what do you use?
I’ve tended to use a soldering iron and a solder sucker but I’m looking for something a bit better (I’ve been doing the same thing for 25+ years now… thought there must be something better)
yes I have a hot air iron, and use solder wick for smts … looking for through hole solutions
I have been training staff for many years on soldering and de-soldering PTH, surface mount and area array packages. I have included some guides which may be useful. I have also in the past produced training videos on the subjects. The best method for de-soldering PTH as has been said is a vacuum system but expensive, With practice a plunger solder sucker can be use with plated through hole but not on multilayer Bob Willis p11Hand soldering2016.pdf (766.9 KB) p26 SMT Rework2016.pdf (3.5 MB)
if you want a laugh (I was not!), I soldered up the servo header on a SpeedyBee f405 wing… followed by a few other connections for other stuff jumpered off the board… plugged it in and (you guessed it!). the header pins were on the wrong side of the board…
