Apologies if this is in the wrong place. If it is I’ll delete it
I had a couple of instances recently when the Neo flying with the RC-N3 controller went berserk and flew full speed in a straight line untill it hit something.
It’s “inconvient” and a real confidence shatterer for a newbie. This first time it was close to me on a beach and flew into me so no damage done. It was only 8 satalites and it then did throw up a satellite warning but from the Flight Records it then went into ATTI mode. Cancel didn’t stop it.
On new years day it was a lot more dramatic. Well actually dangerous.
Flying directly above my head at 90 ft. Home point updated. Nearly 20 satellites.
At 180 degrees in a 360 yaw I got an Amber No Satellite message (flight records say it dropped to 8) then back up to 11 then 15 then more satellites in 0.4 of a second
Everything seemed fine as I was still in a slow yaw untill I centered the Yaw stick at 360. The motors then went nuts. It then headed off the the direction it was facing when the No Satellite message came up. It reached 52.6mph according to the Flight Records before it hit a hotel.
Pause and RTH didn’t stop it
It was an open area with no trees or obstructions
If it had hit someone it could have been… Unpleasant or even caused an accident.
The Flight Records show it went to Auto RTH when it was already accelerating away from Home then into Go Home mode…while flying on full throttle away from Home!
İ couldn’t recover the drone as it was inaccessible but that’s the least of my worries. This type of behaviour is dangerous. From the Internet it looks like there are lots of similar concerns with the Neo and N3 controller.
I have a Fly Away case with DJI and they will analyse the logs but as I’ve looked at them myself I can’t see anything I didn’t do or could have done to prevent this.
I want to push DJI really hard to take this seriously and fix whatever is wrong before somebody gets hurt or it further damages the reputation of responsible pilots.
I certainly won’t attempt to fly it on the controler again after the hopefully replace it free of charge.
Any further thoughts or advice appreciated.
