Been to north east today
I made the mistake of trying a range test over North Sea.
Just made it back ![]()
Forced RTH at 3700 meters.
lucky you, could have lost never go further than what info says.
Tech works ![]()
It tried to force land at 10%
I had to take over and made it back at 1%
I was sweating a bit
Yesterday I tested the battery on my mini 3 pro. I got to 1% and then 0% and still got an additional 4 minutes out of the battery with it circling about 1 m above the ground. Eventually it wouldn’t let me override the forced landing and it landed itself.
Good to know.
I was sihting it abit
Are you sure? Max speed is usually highlighted in purple in AirData
I will check again
I have checked
There is no highlight speed .
Strange. Never seen it without. ![]()
(And I check a lot due to the Breaking the Speed Limit thread.)
Likewise the text in the “Message” column isn’t there.
I made that mistake the other week & lost it in a lake
never mind ( force land ) if I knew back then what I know now I could have made it !
Drone down lesson learned!
Bad luck!
What drone did you lose ?
Mavic air 2 ….
Did you have insurance?
Had 9% battery left and 200 feet to ground
could of done it but I panicked
Yea all sorted in less than 24 hours ![]()
I did aswell
Today was the first time h ave let it run down to 9%
Lessons learned -
Wind an return flight will use more power.
Can over ride forced landing.
I have been informed it will still fly beyond the 0%
I will do my next range test on land.
Coverdrone or Dji refresh ?
Yeah before I attempt that again I will be planning what to do in an emergency of force land , I didn’t know I had to keep the stick pushed up
I was to busy looking at the screen trying to cancel which it wouldn’t ![]()
